Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Can't Sign into Fusion 360
4 REPLIES 4
sean_minihanesullivan
159 Views, 4 Replies
Hi I am having having this issue as well. I was wondering could my account please be reset? Thanks
[Admin moved message to a new post, it was not tied to the other messages.]
4 REPLIES 4
Hi @sean_minihanesullivan
Can you confirm that your acquired a Fusion 360 Education License? The steps are listed below.
  1. If needed, sign into the Autodesk Education site.
  2. On the Individual tab, on the Fusion 360 product card click "Get product".
  1. Click on "ACCESS".
  1. Launch Fusion 360 (if you're running Fusion from a browser, you can cancel the install).
  2. If the Education license does not appear on the top of Fusion's screen as shown in the following image, sign out and back into Fusion 360.
Please keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
I was able to change the status of your Fusion Team from Closed to Active. Please try to sign into Fusion now.
-Dan
Dan Banach
Can you confirm if you are now able to sign into Fusion?
-Dan
Dan Banach
Problem is fixed.
Thanks.
You've got Fusion.
