Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Can't access Fusion 360.
2 REPLIES 2
jmackniak
101 Views, 2 Replies
[Admin moved post to a new thread, this issue is different than the original]
So frustrating.  I cant access Fusion today either.   i go and open the app - asks me to sign in - doesn't work and is supposed to send me to the web browser, that does not work either.  I search and open a link for logging into fusion 360, when i do i get this message:
What is the answer to reference 112??
Ooops ...
Looks like we couldn't verify some of the information you submitted.
Please contact us at the page listed below and reference error #112 so we can sort it out and get you into your account.
www.autodesk.com/signinhelp.
2 REPLIES 2
dan.banach
in reply to: jmackniak
Hi @jmackniak
Sorry you're having this issue. I'm not seeing any issues with your account or Fusion. Is it possible that your IT Admin made a change to the network?
A couple things to try.
  1. Can you sign in and run Fusion 360 from a browser (Chrome is preferred) by going to https://fusion.online.autodesk.com and sign in with your Autodesk Education ID (same email that you log into Fusion 360 with)?
  2. Can you please try the steps in this article: "Sign in Failure: There was an error while logging in to Fusion 360".
Please keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
Hi @jmackniak
Can you please try to sign into your Fusion Team at https://login.autodesk360.com and let us know if you have success?
Also, I can also see that you only have a Personal Hub / Single-User Storage. Can you try to create a Fusion Team via the Fusion Onboarding site? Then sign into Fusion.
From this same site, you can also transfer your Single-User Storage projects to your Fusion Team.
-Dan
Dan Banach
You've got Fusion.
