Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Browser and other floating window disappear
1 REPLY 1
danlr46
163 Views, 1 Reply
The browser, the navigation bar and contextual palettes disappear from the application window; they are behind the main window, to get them back I have to activate Exposé function on my Mac1 and click on it. When finished the task the they disappear again, hidden behind the main window.
Also the ViewCube sometimes becomes inactive, to resurrect I need to activate the orbiting function via the Marking Menu
1 REPLY 1
dan.banach
in reply to: danlr46
Hi Daniele,
Thanks for the post. Here are few ideas.
  1. Try resetting Fusion defaults: On the File menu click > View > Reset to Default Layout
    2. Try to limit the graphics in Fusion 360. Here is an article that explains the steps.
    3. If these doesn't solve the issues, try updating your video driver and make sure all the computer updates are installed. Then restart your computer.
Let us know if one of these resolves the issue.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
