Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
beginner question: how do you make a varying complex curve? pictures in description
1 REPLY 1
yinyangrex
106 Views, 1 Reply
I'm modeling this saw handle for practice and I'm trying to replicate the curve in the handle (like the inner curve)10-in-dt-qs-cherry-006.jpg
here is the model I have, am I on the right track with the sculpting feature?
1 REPLY 1
dan.banach
in reply to: yinyangrex
Hi @yinyangrex
This a a great design example to try to replicate. A couple thoughts and ideas.
  1. I like the approach of using surfaces to remove geometry. Ensure that the surface fully encompasses the geometry you want to remove.
  2. You could also try to loft between two profiles. Then you remove material by extruding profile and adding fillets and chamfers.
Do other have more ideas?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
