Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Autodesk Learning Pathways will retire December 6, 2023
3 REPLIES 3
tsmith29NCK
311 Views, 3 Replies
Reaching out to see if anyone has any insight on anything that may be replacing the pathways? From what it looks like, the Learning Pathways webpage directs you to Autodesk Learning, which has short tutorials and curated lists of tutorials to watch.
I like using the pathways because the videos, quizzes, and challenges are all in one place to send students to learn the software. I have been using the 3D modeling for manufacturing and CAM for Design and Manufacturing pathways in my classes.
3 REPLIES 3
dan.banach
in reply to: tsmith29NCK
Hi @gregory.cohen9FQ56
Can you please answer tsmith29NCK question about the Learning Pathways?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Hi  @tsmith29NCK -
Good news - all Fusion 360 skills development courses under Learning Pathways will continue to be available into 2024 so you can continue with the same courses. Cert prep courses for all products will also continue to be available in 2024.
Course retirement applies to the skills development courses under Learning Pathways for Revit, AutoCAD, Inventor and Civil 3D.
In case it's helpful, these are all of the Fusion 360 Learning Pathways
Let me know if any other questions come up - always happy to help.
Cheers,
Gregory
https://drive.google.com/uc?export=view&id=[file/d/1v1VfZdhmj9WMJjl1NWBjpUg3lFLvMp0j/view?usp=share_link
Thanks @gregorgy.cohen9FQ56!
You've got Fusion.
