Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Autodesk Education plan
3 REPLIES 3
ylhiew
226 Views, 3 Replies
3 REPLIES 3
dan.banach
in reply to: ylhiew
Hi @ylhiew
Thanks for posting your question. From your description, applying to become an ATC may be the best path forward. In Malaysia, you can contact The Network Hub (NWH Holding) or email them. They oversee Autodesk's Learning Partners in your area.
Does this help?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
ylhiew
in reply to: dan.banach
Hi Dan
Thank you for your reply.
dan.banach
in reply to: ylhiew
Hi @ylhiew
Thanks for the additional information. It does not appear that you qualify for the Autodesk Education Plan as an educator or institution. For reference, for those that are reading this post see the following links. I still suggest connecting with The Network Hub and explain your situation. I believe they support Malaysia.
Please keep us posted.
-Dan
Dan Banach
You've got Fusion.
