Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
align tool does not work on moving components to origin
3 REPLIES 3
patrick_william
165 Views, 3 Replies
 I can't get this to do this. want to move individual components point to point to the origin. I created first tier as component/ then imported svg as a sketch/ then extruded it/  I want the origin not to be floating in space be be in touch with the component. I can do this with the body part of the component but the sketch does not come with it.
3 REPLIES 3
the component will only align with the
here is the file
Closing this post as Accepted Solution. This question is answered in this post. want to scale component using dimension tool by having only one dimension not use percentage
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
