Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
3D Fillet Not Working Properly
3 REPLIES 3
cdacost2
133 Views, 3 Replies
I am currently making a part for a summer class and my 3D fillet tool seems to not be working properly.
As you can see above it seems to just do this instead of shaving off the side. Anyone know a work around or why this may be happening in the first place?
3 REPLIES 3
o.briggs
in reply to: cdacost2
Hi @cdacost2
The first thing to check is that you don't have a second body inside the first. this would explain why filleting one of the bodies leaves the second behind!
Check the bodies section in the browser.
If you share the file with us here it will be a lot easier to determine the issue!
Oliver Briggs
Community Manager - Education
Are you an education user?
Check out our Students & Educators Community
Please 'Like' posts that are helpful.
If a post answers your question then feel free to click the 'Accept Solution'
cdacost2
in reply to: o.briggs
I can send you the file, what file type should I save it as?
o.briggs
If you could upload it as an F3D file I can open it in fusion and be able to help! 😊
Oliver Briggs
You've got Fusion.
