Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
2D Slice of a 3D object
3 REPLIES 3
mma9138
160 Views, 3 Replies
I am trying to cut a 2D slice of a complex object that I have. I need the slice to be strictly 2 dimensional as it will be used in COMSOL for modeling. Any help is greatly appreciated 🙂
3 REPLIES 3
dave_taylor
in reply to: mma9138
Create a Construction Plane where you need the slice. Then you can use Inspect>Section Analysis to cut the object at that plane, so you can see the bodies/components cut there. Then make a new Sketch on the Construction Plane you created and use the 'Project' (p keyboard shortcut) to project the geometry profile lines to the sketch. You will have a sketch with the profiles and you can export it by right-clicking on the sketch in the browser-tree and 'Export to DXF.'
Innovation and Development Strategist
Synergis Engineering Design Solutions
Autodesk Certified Instructor
Try out our vault add-in: Vault Sidekick
*Likes to this post are appreciated if the information I have shared is helpful to you and/or others...
**Did this resolve your issue? Please accept it "As a Solution" so others may benefit from it.
mma9138
Thank you so much for your help. It does not work for some reason when I try to project the geometry profile lines to the sketch, it does not appear to select my object. I tried with a simple cylinder and it worked fine. Any idea on how to fix this?
kellings
Can you post your file?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
