I have a design of a small ball chain sprocket used in a motorized weight lift for a pendulum clock. My problem is that I can not make the sprocket holes deep enough because core of the sprocket has to have a cavity to accommodate the gear box of an N20 gear motor. In my present design I have only about 60% chain rap and it can slip. What I need is full rap of the chain but this would require a threaded like sprocket where the entrance is on one side and the exit is on the other. Imagine a spool with 1/16th" divots that enter on one side of the spool and exit slightly to the left or right of the entrance. The sprocket has 15 teeth and the chain is .1739" center to center on the balls or 69 balls per foot. I am just to new to Fusion to tackle this type of design. I do have some stl files of the sprocket as designed if needed.
Thank you in advance for responding.
wz0m
