Zooming to 0,0,0 upon selecting sketch command
Often I'll be zoomed in on a feature when selecting the sketch command, and once a plane is selected the view changes to be centred on 0,0,0. Obviously that's very annoying as I then need to go back to the area I'm working on and zoom back in to continue the sketch. I've tried to do a search on a solution for this but am not even sure what the behavious would be called, so I'm not having much luck with general searches.
I presume this can be turned off or some other work around found, in which case I'd be grateful. Hopefully I desxcribed the issue clearly enough.
Maowen_Zhang
@Anonymous,
I think the option "Auto Look At Sketch" is what you need (auto rotate camera for sketch creation and edition), please uncheck it and let us know whether it works for you. Thanks for posting!
Lori Zhang (Fusion Development)
Yes, thank you very much. I KNEW there would be an option there to turn that off, but there's no way I would have found that! Much appreciated!!
Maowen_Zhang
Very welcome! Thanks for the posting !
