Zoom level affects selection
nkloski
Message 1 of 8
nkloski
I am not sure if this is intended or not, but I don't think so.  I sketched some text (OpenText), and then exploded it into curves, like this:
If I left -> right drag select, I get this...note that I have highlighted in yellow some sections that decided to not get selected:
That should not happen....the selection box I dragged around the entities should select everything under the selection box, not "only the larger things".  Note that if I zoom in, and do the same selection, everything gets selected:
Ideas?
Thanks!
Nick Kloski
Replies (7)
Message 2 of 8
jeff_strater
you are right, that is not the way it's supposed to work.  We'll look into it.
thanks for pointing this out.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 3 of 8
nkloski
Thanks!
Nick Kloski
Message 4 of 8
jeff_strater
One thing that might help us: What font did you use for the text?
thanks,
JEff
Jeff Strater
Message 5 of 8
nkloski
I get that on pretty much all fonts...here is an example of Arial:
Nick Kloski
Message 6 of 8
nkloski
Hiya...any word on this?  I see that it affects others as well!  If you look at Curtis' screencast on engraving, at the 6:00 mark, you can see him try to window drag select, and not everything is selected...I can't see where to open a bug on this, but it heartens me that others see it too!
If there is a place to report a bug, I would happily do so.
http://forums.autodesk.com/t5/design-differently/cam-for-fusion-360-engraving-a-logo-amp-working-wit...
Nick Kloski
Message 7 of 8
jeff_strater
Thanks, there has been a bug filed on this:  UP-16825 is the internal tracking number.  We hope to fix it as soon as possible.
Jeff Strater
Message 8 of 8
nkloski
Awesome, thanks!
Nick Kloski
