WRONG model size after extrude
helsork
Message 1 of 12
helsork
Hello folks,
I have problem with model sizes after extrude model from sketch.
Example: I draw 878.8 x 484.2mm rectangle. Then extrude 0.6mm and when I measure the dimension in (all decimals) I got 878.7999999999999545 x 484.1999999999999318 mm. Why is this happening? How to solve this?
Thanks for answers.
ErrorError
Replies (11)
Message 2 of 12
TheCADWhisperer
Message 3 of 12
helsork
Thanks for answer.
Yes, I can. Each time I draw a new rectangle and extrud I got different dimensions after the decimal point, But still, it’s never an integer.
Message 4 of 12
helsork
The biggest problem in preparing a part for folding is because all the walls come in different thicknesses and fusion 360 not understand.
Message 5 of 12
mango.freund
you're right, it doesn't work that way, when everyone knows that the answer to all questions is 42.
Just next to it is over even if it is a few trillionths of a millimeter. greetings mango
I'm curious about the answers.
Message 6 of 12
TheCADWhisperer
Why not model in finished form and let Fusion generate the Flat Pattern for you?
What are you attempting to model?
More information is needed.
Message 7 of 12
helsork
Here’s the problem that fusion 360 doesn’t make a mat. because the dimensions run through the errors and don’t unbend the mat. Anyway, I don't understand why it doesn't allow you to make models with integers. I understand that this is not a big mistake, but I would dont want such errors when drawing a device. And extruding the model should not change the dimensions by itself 😞
Message 8 of 12
helsork
Attach another model. All surfaces of different thicknesses... I tried to put a sketch on the surface and then hide the model for new extrude out the new part (2mm) but I still get 2,00xxxxx or 1,99xxxxx
Message 9 of 12
mango.freund
Please take a look at your preferences and use - as is usually the case in the technical area - no more than 3 digits after the comma.
Message 10 of 12
TheCADWhisperer
This part is modeled incorrectly.
Where is your history?
Since there is no history - I will have to remodel the part from scratch.
When I remodel it - it will work fine.
Are you sure about this?
Message 11 of 12
TheCADWhisperer
@helsork
Where did you go?
I finished it as fast as I could go.
Message 12 of 12
TheCADWhisperer
@helsork
What happened?
