Working in form
Working in form
design1JMDX8
Working in form
design1JMDX8
Hi everyone.
I started using for and I've come up with a design I like.
Here's the but.... I want to keep it as a ridged shape, sharp lines and sharp corners.
Is there a way of "converting" it to a solid body or a surface without it loosing its shape and going to the soft shape?
Thanks in advance
g-andresen
what do you want?
no image, no file?
günther
jeff_strater
If you want sharp corners and sharp lines, why are you working in the Form workspace?   Form (T-Splines) is specifically intended for making soft, curvy, "organic" shapes.  It sounds like you might be better off working in solid or surface BRep mode.  As @g-andresen says, it is very hard to help without more information...
Jeff Strater
Engineering Director
