- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone!
I am working on a production and testing jig for an electronics project. The main idea is that there is a top board in which PCBs slot into. To get a general idea of what I am talking about, look at an image of the design at the bottom of the post. The thing I can't wrap my head around is what kind of workflow to use to design such a thing, so that it can be easily modified without messing up the whole design. There are two ways which come to mind: insert a 3D model of the PCB, try and align it manually roughly where I would want it, project the outline of the PCB in a sketch, add an offset for the outline to include some tolerance and then cut out the outline from the mounting block. This seems like a rather messy approach, plus it means I have to do a lot of eyeballing in terms of alignment. Modifying the PCB design usually breaks a lot of the design as well.
The second approach I see is to generate a dxf file from the PCB CAD, insert that as a sketch, use it to make my cuts and then use a rigid joint to insert the PCB in the cutout. This seems to be a bit better but it also means I have to fully constrain the PCB outline in a sketch in order to constrain its location without messing up its outline because as far as I can tell, fusion 360 has no sketch blocks. For more complicated outlines this makes the sketch a total mess and is therefore also undesirable. Ideally I would just have a dxf import behave as a single entity in a sketch that is fully constrained against itself but its absolute location can be set using constraints.
I've used both workflows in my designs previously it wasn't very fun to say the least, so I'm thinking there has got to be a better way to get this done.
I'd appreciate any input from you folks on the best approach for this so that I can stop tearing my hair out any time I have to modify either the PCB or the jig design.
