workflow multi position for Folding project
Francois_Moreau
Advisor Advisor
Francois_Moreau
I search a workflow for make some folding with Vbit CNC
what I easiest find is here
Make extrude on a master
assemble it flat, make some changement, extrude it again with the angle off the bit
and make one more Move to find back the 3D
like it is possible with Config, but need a lot of step, do I miss something to find an easiet way?
https://a360.co/44opNZB
François Moreau
bénévole sur le programme Expert Fusion:
kacper.suchomski
Hi
Finally, you can define constraints and configure operations (or constraints) to define positions.
Kacper Suchomski
Francois_Moreau
thanks @kacper.suchomski
I will try also like that, but my question  still to be, how to switch in the 2 positions of the "origami", like I do first the ruf 3D shape, then I open it, add somme small stuff (in the way you do) then back to 3D shape, back to flat position, I still search for the most practical way,and the idea of filet will help me, thanks
François Moreau
gautham_kattethota
@Francois_Moreau you could configure Position Capture feature or Joints/Constraints that you use for rotation so that you can capture the flat and the folded orientations using Configurations.
Gautham
Gautham Kattethota
Software Development
kacper.suchomski
Maybe this:
Kacper Suchomski
Francois_Moreau
yes
I was thinking I must wait that config with position stronger dev would be
config 1
Config 2
and Config 1 when I put the position at the End
all wright
config do not resolve this stuff with time line, so you must re-do your Move / position back every new change
I will try a video
François Moreau
