New to Fusion, coming over from Rhino and really struggling with some of the core principles and approaches. I'm trying to model a frame made from straight pieces of pipe and angled corner fittings. After watching and reading a smattering of tutorials and help articles, thought this would be the appropriate workflow:
- Create a 3D sketch of half the frame, just as a placeholder for where components will be in relation to each other in space;
- Model 3-way and 4-way fittings as separate components, use rigid joints to attach copies of each fitting to each frame sketch point, constrain fitting sketch lines to be parallel to frame sketch lines;
- Extrude pipes from one fitting to the next and attach with joints, each pipe a separate component;
- Mirror geometry to create other half of frame;
- Model centerline fittings and pipe;
- Parametrically adjust constrained frame sketch points as needed and watch Fusion magically adjust pipe lengths and fitting angles accordingly;
- When finalized, export a list of cut lengths for all pipe components and 3D-print ready files of each fitting.
Based on the welts from smashing my forehead against the keyboard for several hours, I'm guessing the whole approach is wrong, or missing crucial steps. Could some kind soul help steer me in the right direction?
File attached, but for reference, here's a screenshot of the frame sketch, and an attached fitting down in the corner. The sketch for the fitting is just 3 lines, so ideally I'd want to align each of those lines to a line of the frame, so if (for example) I change the angle between two frame lines, the fitting sketch lines automatically update to match, if that makes sense.
