Message 1 of 12
Work Plane Problems
08:50 PM
During this social distancing time, I am trying to learn the basics of Fusion 360. I am trying to follow along with some of the YouTube videos by Lars and others but I have a problem. When I try and create an object ( in this case a simple center rectangle ) once I extrude it, the object always shows to be below the work plane. The corner orientation cube shows correct but the item is below the work plane. Any ideas what I am doing wrong?
- Create sketch
- Select XY plane
- Select center point rectangle
- Select center origin mark for rectangle. Form rectangle
- Esc
- Select rectangle, it turns blue.
- Select E for extrude. Raise blue extrude arrow up 40mm. Enter.
- Rectangular box shows on blank background
- Select top of rectangular box. Matches corner cube orientation.
- Select “Create Sketch”.
- If I select the corner of the corner cube for an angled view, It shows the created rectangle below the work plane with the top oriented against the bottom side of the workplane.
