Wood simulation on Fusion 360
I use a MacBook air. I work on airplane models and use wood as main material. I need to run simulation on wood. Is there any alternative to fusion 360. (Maybe add wood sim in fusion) What can I use for mac to study wood or i’ll have to get solidworks ?
johnswetz1982
What do you mean by "Simulation", FEA? or CAM toolpaths?
Sorry i didn’t make it clear. I mean static loads etc. FEA
johnswetz1982
You probably would want to check the design Forum they may be able to give you a better answer (Move @seth.madore ?).
Fusion can simulate wood in the simulation tab, I assume you would want a non-linear static stress simulation. What I see as the problem with Fusion is that it would require cloud credits for that rather than be able to solve locally on your machine, but I may be missing something.
Yeah non linear static test when initiated the wood is described as Non-linear material and fusion can’t run the simulation.
It says some components use a material with invalid properties.
philmartin69
Observer
Observer
yeah im in the same boat here, anyone find a solution yet?
TrippyLighting
If you can share the design, perhaps I can tag one of the simulation gurus.
