Windows trackpad orbit
travis
Message 1 of 37
travis
I apologize in advance if this information is already listed somewhere, but for the life of me I can't find it.
How do I get my windows pc to orbit with a trackpad?  This is available for Mac but not for windows.  Tried all different combinations of two finger swipe + shift + ctrl, etc.  nothing seems to work.
Please help
Replies (36)
Message 2 of 37
masa.minohara
Hi @travis,
Thank you for posting! I am using a Dell Precision and it has a touchpad with three buttons. I can rotate the view with Shift + center button and a single finger swipe, and I assume this can be different depending on what machine you are using. Could you try checking the touchpad settings on our machine?
A workaround is to use the Orbit command at the bottom of the screen but I recommend that you use a mouse for CAD operation.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 37
travis
Hello Masanobu,
Thank you for replying.
The vast majority of the time I use a mouse, and only use the touchpad when absolutely necessary.  I recently purchased an MSI with only two buttons built in.  I was hoping to find a keystroke that works, but I'll resort to the orbit command.
Thanks again,
Travis
Message 4 of 37
Hi guys, just wondering if there is a solution for this issue. My switch from mac book pro to surface book has been painful. Navigation was so easy on my mac with two finger + shift. Now i have to keep switching back and forth between pan and orbit tools its much slower. Please let me know if missing anything. Thanks for any help.
Message 5 of 37
I'm also just trying a windows machine after a decade on mac.
There are a few key issues (Cntrl location vs. Command button) that I think I can train my fingers for ... but ...
The base trackpad navigation is a real bear.  The mac trackpad just "worked" - and now i'm hunting through forums to try and see how I can quickly zoom / pan / orbit / etc ... I don't want to be slowed down because of interface issuers 😞
Message 6 of 37
Message 7 of 37
TrippyLighting
Based on my experience on a high spec Surfacebook there is only a very limited number of gestures available on a Windows trackpad compared to a mac. I don't own a macbook but know at least one Fusion 360 power user that owns both and feedback is the the mac trackpad is far superior.
Message 8 of 37
Yes - I have been on the PC for about 2 weeks now - and find the Windows 10 environment perfectly fine.
The location of the Control Key vs. the Apple Command key seems a little backwards as it forces one to use their pinky instead of the thumb for one of the most used keys.  The command key feels much more natural.
I find the touch screen pretty helpful at times - silly sounding but especially with the calculator!
However - the Mac Trackpad is an amazing piece of engineering.
Question - how do you find Fusion 360 on the Surface book?  Is it powerful enough?
Thanks!
Ethan
Message 9 of 37
catlord
... so I found this thread looking to find information about trackpad gestures on Windows.
Knowing that Fusion 360 has great support for trackpads on Mac OS I am very disappointed that I can't even pinch to zoom on Windows (instead having to mimick scrolling), much less use my fingers to pan or orbit. This requires me to use a mouse which I otherwise wouldn't have to do.
I am otherwise highly impressed by Fusion 360, just this (and missing support for Linux) is marring the experience a bit.
Message 10 of 37
matt30ne
same story here, i've just got a Surface Book 2 and I am having trouble orbiting with the trackpad (and with the mouse since I wanted to be stilish and got a Surface Arc device). Autodesk, would it be possible to add some serious gestures to trackpad on Windows? thanks!
Message 11 of 37
I know I'm a bit late on this discussion... but most laptops allow you to press the left and right "mouse buttons" simultaneously to simulate a middle mouse click. Shift + LMB + RMB works for me on Revit at least.
Message 12 of 37
Whats the official stance on this? Just got a new thinkpad with W10 and using two fingers or the middle mouse button all i can do is to zoom.
Are notebook gestures supported on Windows?
Message 13 of 37
joe.bruce.psu
Observer
Observer
+1. Fusion 360 works so well on my MacBook Pro (though recent updates have had some focus issues), but teaching my daughter to use F360 on her Windows 10 PC -- which has just as capable of a multi-finger trackpad -- is SO painful because of the slow pan / orbit.
Any progress on trackpad gesture support for Windows, Autodesk?
Message 14 of 37
darkforcesabers
Sorry to Necro-thread this, I haven't seen this mentioned yet on the forums; but for those looking for a more factory solution that doesn't require a third-party scripting app; try this:
1) Go to "Preferences".
2) Click on the "General" tab.
3) At the bottom, uncheck the option that says "Use gesture-based view navigation".
4) Restart Fusion.
This will allow you to use the orbit tool too navigate your projects, simply by using a shift+ right click & drag motion.
(I know on Mac it's accomplished a little differently by holding down shift+ drag. But this seems to do the trick just as well on PC, with a little getting used to!)
You can also make sure "Reverse zoom direction" is enabled- in case you liked the factory trackpad zoom function of a Mac's as well.
Message 15 of 37
Shift + 2-finger drag to orbit does not work for me on a Windows laptop with a touchpad. I tried disabling "Use gesture-based view navigation" in the Fusion 360 preferences. Didn't work. Re-enabled it. Didn't work. In either mode it doesn't seem to have an impact.
Info about my system. Windows 10 Pro on a Dell XPS 15 9500, 10th gen Intel processor, 16GB Ram. All of the latest Windows updates are installed.
Any other suggestions as to how to get this working?
Message 16 of 37
stonejo
Observer
Observer
I was having the exact same problem and looked into mouse remapping software, but that was a dead end.
In the process I found that you can hold F2 for pan and F4 for Orbit. Additionally F3 is zoom and F4 is home.
Hope this helps!
Message 17 of 37
aaronzoltan
Is there a response from autodesk on this??? I also use W10 and have no shortcuts known to me about pan or orbit. This slows things down immensely. Hello? Autodesk?
Message 18 of 37
aaronzoltan
I apologize for my ignorance on this, but I tried holding F2 with and without ctrl, fn, alt, windows key, and cannot get the pan to work. Would you be able to clarify this technique or direct me to a link with the information?
thank you
Message 19 of 37
stonejo
Observer
Observer
You have to be in "fn lock mode"
Just hit fn + esc. None of your regular f-key shortcuts will work (volume, brightness, etc.) unless you hold the fn key. It's kinda like caps lock that way. once you are in fn lock, you hold down the f-key that corresponds to what you are trying to do. For example when you hold f4, you should see a crosshair appear for orbit.
Message 20 of 37
Pushing this thread cause this function is needed...
otherwise the software is barely usable with just a trackpad
