Windows 10 Problem
Windows 10 Problem
LDF09
Windows 10 Problem
LDF09
I upgraded my PC to Windows 10. Now when I run F360 I get:
I already am logged on to A360, but I do it explicitly via the webpage to verify.
I press OK.
The dialog goes away.
F360 comes up, stays for ~800ms, then disappears.
I've uninstalled/reinstalled several times. Always the same behavior.
Am I the only one having the issue?
LDF09
For whatever reason, this has fixed itself.
Marking as done.
baribak
I am glad to hear this issue is resolved.
I am not sure this is related but we were in a maintenance period. However the error message you received is not correct.
We will check this out. Thanks for the heads up!
Kevin Baribault
Fusion 360 Quality Assurance
