Will there be a tapered thread command?
Oluwayimika_OLA
Oluwayimika_OLA
It would be wonderful to have the thread command not fade away on tapered surface as it did in the image above. Using coil command can be tedious when the threads to be achieved are ACME threads.
etfrench
Tapered Acme threads can be done in a similar manner as tapered pipe threads.  Use a square profile tapered coil. Chamfer the sides with distance and angle (29 degrees).
These will probably work for 3D printed objects, but may not be suitable for precision or high pressure.
ETFrench
lauri_barnhart
Hi @Oluwayimika_OLA,
Did the info from @etfrench help answer your question?
If it did, it’d be great if you could click the "Accept Solution" button so others can easily find it too.
If you’re still needing more help, feel free to share an update here. The community will be happy to jump in with any next steps to help you get where you need to be.
Best,
Lauri | Community Manager
