Why my shared assembly file always show out of date reference
I can open the assembly file but cannot do any simulations because it shows multi-parts are out of date reference. I have full access to these files.
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion Community! I'm sorry to hear about this issue.
What build number of Fusion 360 are you using? Can you check this in the Help > About dialog box? For example, my current build number is 2.0.2316. If you have any pending updates, please install them and restart Fusion 360.
If this suggestion does not help, please post a copy of your diagnostic log files so that we may review this.
I note the below forum discussion seems to be about a similar behavior and may also be helpful.
http://forums.autodesk.com/t5/design-validate-document/issues-with-asemblies-in-latest-update-s/m-p/...
I hope this helps. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
I cannot figure it out. The diagnostic file is attached
ahsan.autodesk
Hi @Anonymous,
Thanks for sharing the log files. Sorry about the troubles you're facing. Looking at the log files, it appears that you're having trouble opening some files referenced from the main assembly. For example, the log files show that you're having trouble opening the referenced file "Junction Box Back Wall". Can you please try and open that file by itself and see if that works?
If it is possible, can you share your project with me - ahsan dot ali at autodesk dot com. I may be able to give a quick look and see what could be wrong with that file.
Thx and regards,
Ahsan (Fusion Platform)
Ahsan Ali
Fusion Senior Software Architect
what happened when I click that file and show      initializing document manifest xml stream failed?
Beside the back wall file, still have a lot of warning sign.
