why imported object is not interacting with fusion functions ?
khaleel89mas
khaleel89mas
Good afternoon every one.
When I import 3d designs from SKP to OBJ extension, program is not able to detect edge lines or midpoints of the design sides, also other functions such as push, hole, create & modify are not applicable in design, see video V2
also I am unable to fit pivot point as I need for rotation animations as video V1 , cant shift or change pivot anyway.
If any helper can advice me about the design problem if its from the imported item or if there any missing options.
please contact me whatsup
00971521116208
TrippyLighting
If this is a Sketchup export then it's a mesh. Depending on what you want to do with it FUosn 360 may not be the right software to make modifications.
You can try to convert his into a BRep and then work with that.
1. "Create -< Base feature"
2. Right-click on mesh and select "convert mesh to BRep"
3. If that worked, then finish the base feature.
Now you can work with some of the FUiosn 360 tools.
Maybe you should explain what you want to do and attach the Fuiosn 360 model in .f3d format to your next post.
