Why I cannot paste body to project?
wintarif
Message 1 of 10
wintarif
I'm trying to copy and paste body from "Fan base" project to "Circular duct" project (see attachment). I can paste that body into other projects, but when I trying to insert into "Circular duct" nothing happens, no new body appears, but "Paste" changing to "Repeat Paste". Is this a bug or as always some special steps required?
Replies (9)
Message 2 of 10
Beyondforce
Hi @wintarif ,
Maybe this will help you understand how to copy body works: https://youtu.be/UJqV_JT0Ll8
IF you want to copy a body to another file, then you can use Derive tool.
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Need a new computer? Fusion 360 Hardware Benchmark: TESREG.com
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
| YouTube
Message 3 of 10
wintarif
There is only 1 body and no components in each project, only root node have option to make it active/inactive. Your solution doesn't helps, it works in any other projects except one I uploaded.
Message 4 of 10
Beyondforce
May I ask what do you mean by "Project"? Do you mean a design file?
Ben Korez
| YouTube
Message 5 of 10
wintarif
Yes. I call it "project" like any project in Visual Studio (except there "solutions") or Delphi.
Message 6 of 10
Beyondforce
First, you must use the correct terminology, Fusion is not Visual Studio! "Project" in Fusion means something else.
If you want to copy a body to another file, then there are several ways to do that:
1. You can use the Derive tool to import/export a body (recommended).
2. Export the component which the body belongs too, and import the component to where you want it (don't forget to break the link).
Ben Korez
| YouTube
Message 7 of 10
wintarif
But "file" also wrong terminology because in file systems copying something from one file to another means something else (and there 3 files per one whatever - xx, png and f3d). I'll google for "Derive".
Message 8 of 10
Beyondforce
In Fusion, Files exist inside a Project. You can also create Folders inside a Project in order to create a better structure for all the files.
For example, I have a project called "Test" and inside it, I keep all the tests that I do that are not related to any specific assembly. I also have a Project called "YouTube Files" with Folders as well, where all the files that I use in my videos are stored there.
Ben Korez
| YouTube
Message 9 of 10
wintarif
"Derive" works.
Message 10 of 10
Beyondforce
Excellent! I'm glad I could help.
Please let me know if you need more help 👍
Cheers /Ben.
Ben Korez
| YouTube
