Why does it keep adding 0.8 to my dimension
champshire91
champshire91
Here is a video. It keeps adding 0.8 to my measurements no matter what. Why is it doing this? Thanks!
https://youtu.be/G391H84v9Pk
John_Wright
At a blind guess (without the model to check) I would say that you have added an offset (or similar) to the geometry later on in your timeline.
Roll back the timeline to the first instance you create that clip feature and see if the behaviour is the same.
John
champshire91
Ok thanks! I will try that when I get home!
