I'm trying to align the four mounting holes of two vacuum motors to what will be a plywood mounting plate.
After that I will project geometry from the motor bodies to make cutouts in the plate for them to protrude through.
The following two pic's show how the two sets of 4 holes in the sketch don't line up with the raised bosses on the round fan housings.
The motors' bolt pattern is rotated 11 deg, so I rotated the motors by that amount.
[Another question: In order to get the handles to show up when hitting M for the Move command, I had to activate the motor component. If I just highlighted it in the browser, the form window came up, not the handles; is it supposed to be that way?]
Motors rotated 11 deg:
When I went into a sketch that I had previously started (it's at the end of the timeline), the motors rotated back:
Why?
I rotated them back, grounded one, and made them a rigid group:
I went into the sketch editor again and the rotated them back again:
What the heck?!
I tried rotating one of the motors while in sketch mode, but it wouldn't move.
Fair enough, since it's constrained.
But when I exited sketch mode it *had* moved.
I noticed that when I go into the sketch editor that the ground on the motor disappeared. grr
I rotated the motor again and put the ground back, but somewhere in that process I got bumped out of sketch mode and when I go back the motor is misaligned again.
I'm totally bewildered and frustrated.
