Why Can't I Thicken A Stitched Together Body, But I Can The Individual Body's?
19458766
19458766
Howdy, this is my first time on this forum so nice to be here. I'm working on an iron man helmet, because you know, I'm a huge nerd, and I've made the faceplate into different bodies, which I know want to stitch together and thicken. However, anytime I try I get an error saying *The operation could not create a valid result, Try adjusting the values or changing the inputs* However when I to thicken the bodies individually, not stitched, it works fine.
Any idea why this is happening? And what I can do to fix it? Or should I just do it individually and leave it that way.
jhackney1972
Please attach your model, containing the surfaces.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Okay, I attached the .f3d file.
jhackney1972
I am pretty sure it is because of the sharp edges between some of the faces.  I added surface fillets, where they would take, and it thickened ok.  I will have to leave this one up to someone else.
hamid.sh.
Not that this is a good solution, but might help you and others to isolate the problem: I found out that whatever preventing successful thicken is in the left side of the helmet, because when I cut it in half I could thicken it to 2 mm (but not more). I think there are problems around the eye... To improve with your current model maybe it's better you first make the thickened body without eyes, then cut them away.
That being said If I wanted to to make this helmet I would do it in From environment, which could help making smoother surface and take advantage of symmetry.
File is attached, with whole the surface thickened to 2 mm (though as I said this is not a real solution, hopefully others will help better).
Hamid
I got it to work, however it was a bit weird. I redid the patch parts on the entire face, but this time including the eyes. After this I stitched it together, then deleted the eyes. After this it worked fine trying to extend it.
TrippyLighting
You are using the patch tool on 3D splines curving freely through space.
No way that this will result in clean curvature, and that is the reason you are encountering thickening problems.
Just look at the curvature map:
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
