Why can't I sketch or edit on curved surfaces like a cylinder?
I'm still new to Fusion, but I was attempting to add a flower my object, based on this photo:
To do this, I thought about creating a cylinder and sketching on the surface, to curve out the flower shape.
So far, I found three YouTube videos that present potential methods to create my intended flower. Although I have the most recent version of Fusion, I could tell that all of these tutorials used the previous versions, since they worked in a a Sculpt workspace, which I assume is the same as the form workspace (after hitting "Create New Form".)
In a nut shell, here are the methods explained in the videos:
1) Cutting shapes from a solid to make custom shapes
When the instructor was drawing directly on the cylinder's surface, I could not do the same thing. Despite following the directions, no matter which plane I select to create a spline, the latter always aligns with the selected plane, instead of the cylinder's surface. Plus, the snaps are also aligned with the plane, instead of the object's edges.
The ideal:
My attempt:
My top view:
2) Creating tangent and offset planes
The ideal:
For some reason, when I try to construct a tangent plane, I can't even select any faces on my cylinder neither before nor after creating the form. However, I can only select a face without selecting the tangent line.
My screen:
3) Using sweeps:
Ideal result
Unfortunately, nothing happened after I selected the path and I can't press "ok." I already tried to adjust the measurements for the twist and taper angles, still nothing happened. Honestly, I just a scribbled it with the line tool, to test this method out.
Does anyone have any suggestions to make edits on curved surfaces? I tried multiple times, but I'm not sure what I'm doing wrong or if there are better methods for the new version.
Also, if there is another way to create the flower in Fusion 360, please let me know. At this point, I suppose importing the flower picture and free handing it would be an option.
Thanks in advance!
