Why can’t I add text to some surfaces?
I imported an stl file of a dodecahedron from grabCAD and I was able to add text to some of the sides. However, when I try to add text to the rest of the surfaces, the text ends up on the inside side of one of the surfaces that I already used. What’s gong on?
aaronkcap
You may have to stitch the body together using the patch workspace. Can you post the file please.
TrippyLighting
@aaronkcap if its really a .stl file then that won't work
Here is the file.  I know that I lost a surface somehow but the other surfaces won't work.
Well, I reuploaded the file (it was not an stl but an SLDPRT) and all the sides now work. I have no idea what I did wrong but it doesn’t matter anymore.
