Why arent my print coming out right???
Hi, I just started using fusion about 1 month ago with cura 4.1 and a ender 3, and when trying to print anything it cuts off about 2 mm on the bottom of the print. I have checked the way it is laid on a the bed in cura and almost everything but maybe there are some settings that I dont know about. Has anyone else had this problem and is there a way to fix it.
P.S: Before using fusion i had only used tinkercad and that always worked.
laughingcreek
This is most probably an issue with settings in cura, not fusion.  But file/export your model as .f3d and attach here.  We can at least check the fusion side of things.
Here is one of the things i tried to print
