While creating an animation, is there any way to select everything right of the time marker?
michaelWDJZX
michaelWDJZX
Lets say you have a reasonably comlicated animation, with plenty of zoom events, exploded views, hide and unhide parts. When reviewing your work, you realize it would benefit from a 1 second pause right in the middle. You can achieve this by:
  1. scroll to the time you want the pause,
  2. ctrl click everything to the right of the time marker
  3. drag all these events to the right by 1 second.
Wouldn't it be great if you could: right click > select all events to the right ?
Or even better: right click > insert time
samuel.templeUCPAE
This unfortunately is not likely to be implemented in animation.
My suggestion is that you can place the marker on the timeline and then right click on an item below and choose "Select all After" or "Select all Before.
Samuel Temple
Senior Software QA Engineer
(samuel.temple@autodesk.com)
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
