Which format is compatible with Rhino?
travis.designer.vn
travis.designer.vn
Hi
I try exporting Fusion 360 to 3 format: IGES, STEP and DWG files. After that I import to Rhino, but they do not keep Hierarchy (as layer)
Reference file: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Use...
Which format can keep Hierarchy (as layer)?
TrippyLighting
Fusion 360 does not use layers. The browsers component/sub component structure for surfaces and solid bodies is exported when using STEP and I believe also IGES.
travis.designer.vn
Hi
I test other format. There are several conclusions:
This is FBX file in Rhino:
TrippyLighting
.fbx files are meh files and as opposed to STEP (for example) do not contain BRep or NURBS geometry.
travis.designer.vn
I agree with you @TrippyLighting . Keep finding other solution.
