I often see projection symbols that I am unable to determine the body or feature they represent.
See an example in attached drawing. Sketch was created on back of the block. I didn't create any projections on this sketch. The projection symbol is at top middle. Thought it was projecting the end of blue line, which separates two surfaces. If this is true, why doesn't the point to the left show a projection symbol? If there is a simple way to determine the projecting body or feature, and you provide it, I can probably figure out the answer. If not, I can upload the model. Thank you,
