Where did the 'Insert Sketch into Design' command go?
oldtbone55
oldtbone55
I've been using the 'Insert Sketch Into Current Design' command to move sketches into a blank design but today when I went did the right mouse click thing the command is no longer present. Has something changed in Fusion that I don't know about or has anyone else run into this besides me?
Thanks.
daniel_lyall
Do you have insert into current design in the right click menu
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
oldtbone55
I couldn't remember exactly what the command was called but yes, it was 'Insert in Current Design'. I think I figured out why the command wasn't appearing. When I opened up a new design I also used the 'Create Sketch' command and had left it open. Once I closed the sketch and went back to the file I wanted to insert the command was there. I'd never done that before but I would have thought that the command would still be there and you would get a message saying that you can't insert a file into the current design while the sketch command is open. Oh well, live and learn.
Gee, should I accept my answer as a solution or is that bad form?
Just kidding. Sorry for sounding the alarm.
daniel_lyall
yes your answer is the solution, so it's fine to select your post as the solution.
Daniel Lyall
The Big Boss
Mach3 User
