Hello all!
One thing that kills me using Fusion is the distinct lack of hotkeys/shortcut keys. I am consistantly calling up the toolbox or shifting my mouse from toolbar to part to toolbar to part to dialog to part to dialog to part to toolbar to part....etc. Moving from my old design program (Vectorworks) where ANY command has a customisable hotkey, the mouse movement is driving me crazy.
The BIGGEST issue I have is, you can't use the keyboard to navigate in most dialog boxes.
For example, if I need to split a body several times, I have to hit "Split body" click the body, move my mouse over to the dialog, hit "splitting tool", move back over the part, hit the splitting body, then hit okay. This is a lot of back and forth of I need to split a body into 5-6 layers (or more sometimes).
Not just in this dialog, but in the Extrude dialog (for example) one can't use the keyboard to highlight/use the drop down menus - I have to click the part I want to extrude, hit "E", change to 2-way (I usually use two way), enter the two dimensions, click the dropdown for "New Body" so it doesn't join, then hit OK.
Is this even a plan? If so, is there an estimated timeline?
Thanks!
