Message 1 of 15
I am able to get the sweep command to produce something, but the result is unexpected. The explaination of what i should expect is:
Orientation
- Perpendicular Keeps the region perpendicular to the path.
- Parallel Keeps the region parallel to the region sketch.
Photo attached is of a simple rectangle swept along a spline path. The command finished to the end of the spline, but I pushed it back to expose the profile at a narrow point for this photo. What might be causing the to not be perpendicular to the spline path?
