What's this type of "friction lock" called - and how to model?
android111
android111
Hi everyone,
Not sure what this type of detail is called, but imagine plastic pieces that meet end-to-end, and on the ends there's "ridged disk" molded into each piece so that when the pieces are pushed together (and held together with a rod or something that runs through them), this "ridged disk" helps prevent the pieces from rotating in relation to each other without applying a twisting force to them?
Next, if you happen to know what I'm describing... what might the best way to do this so that the diameter is about 1/2" ? Prototyping intent is plastic of some type...
Here's a bad illustration:
Any help appreciated!
TheCADWhisperer
Search here on the term "Hirth".
android111
Thank you!
