What replaces Inventor mate/flush assembly constraint with offset?
robopolomsky
Observer Observer
robopolomsky
Observer
Observer
In Inventor I often used mate or flush assembly constraint with offset. Fusion guides recommend align + rigid group instead. However fusion align doesn't support offset. How to achieve such connection in Fusion?
davebYYPCU
Instead of faces, Joints work with (corner, end, or mid) points and Offsets.
Might help...
TrippyLighting
Can you provide that reference?
If this on an official Autodesk channel I'll have it removed as that is NOT a recommended practice!
A single Fusion rigid joint will fully constrain the two plates in your screenshot.
In Inventor you need more than one constraint/mate to do that.
g-andresen
some of many possibilities
(view in My Videos)
günther
