what is the best way to fill a tiny gap I have when trying to join to pipes?
itchytoes
itchytoes
Hi --
I have two pipes I want to join but I can quite line  them up angularly so that they meet without a gap.
What is the best way to fill that gap up?
My pipes are small at 1.5mm diameter
Betty
itchytoes
I answered my own question half-way.
I managed to go into patch mode and created a patch but it is an open body and I cannot seem to be able to join it with the two pipes I'm trying to patch up.
etfrench
Can you post a screenshot of the problem?
I used a combination of solid, shelled, and intersected objects to create the following:
Here's a section view:
ETFrench
itchytoes
Hi --
thanks for the reply.
I posted a screen shot that shows the join where the two pipes meet.
The little wedge piece is the open body that I created using patch mode to fill the gap,  but it is an open body and I cannot
combine it with the main pipe body.
I cannot figure out how to solidify it and combine it.
Betty
jeff_strater
I would suggest trying to use Loft to fill this gap.  You should just be able to select the two faces of the "gap" and loft between them.
Here's a screencast of a simple example:
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
itchytoes
Hi --
Okay, thanks!  that worked!  woo-hoo.
I think I tried loft earlier but I wasn't sure what to loft to what 😉
Betty
