What is "autodesk" when I create a new setup?
What is this "autodesk item" when I click new steup.
I can't do anything with it.  I can't right click, delete, move... anything.  If I create a new project and create a new setup, it doesn't appear... but I've got projects with existing models and simply creating a setup adds this unknown object.
What is it?  how do I get rid of it?
jhackney1972
Can you attach this model to a Forum post.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Hi, please find attached a copy of the board.  I've removed a few parts to make it simpler but still confirmed this weird thing appears.
jhackney1972
During your setup, or as one of your defaults, you have selected an "Autodesk" machine. This then appears under the Setup in the Browser.  You do not have to select a machine but if you do, it will be shown here.  In the Screencast you will see I have selected a Haas and the Setup reflects this.
Thanks so much for the quick turnaround.  I have removed the "machine" since it doesn't seem to be necessary for my CNC machine.
Unfortunate that f360 is unintuitive to have a non-interactable object with a name that makes it impossible to google.
