Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
What have I done wrong here please and how to fix it
3 REPLIES 3
336 Views, 3 Replies
I drew 2 components, one has a body and one does not.  I need to turn them into 1 body so I can make a STL file and 3d print it.
So why does 1 component lack a "body"?
thanks
3 REPLIES 3
Beyondforce
Hi @Anonymous,
I believe this will answer your question: R.U.L.E #1 - http://forums.autodesk.com/t5/post-your-tips-and-tutorials/fusion-360-r-u-l-e-1-and-2/td-p/6581749
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
TrippyLighting
It is dificult to see what might be the problem without havng acces to teh model, however, the culprit her might be component activation, or better the lack of it.
When you attempted to create the second body in component6  you migh still have had component5 activated.
When you created the geometry it auto-joined to the first body.
In either case, the end result would actually an empty component.
When you use the Modify-> Combine (join)" command it will absorb the tool body, unless you eneable "keep tool bodies".
If you don;t nbeed that empty component anyore you can use "remove" to remove it from the browser and timeline. You should not "delete" it, however.
in reply to: TrippyLighting
I closed and saved thedrawing and then opened it again and the "body" appeared fine so its likely it is some sort of bug.
