What happened to the offset command, I can't offset a line that I offset
#1 It looks like the offset command changed.  I can't just choose the direction and add a value anymore.  I have to add a positive or negative number. Is that permenant?  I don't like it.
#2 I can't offset a line that I just offset.  It can't even be selected.  I can only offset a line that was drawn with the line command.  Whats up with that?  Is this a permanant change or is there some setting?
Thanks in advance,
Craig
jiang_peng
#1, Now the offset is parametric offset. In fact we can directly drag the manipulator when creating offset:
#2, we don't support offset the offset curve. Workaround and explaination please see this thread:
http://forums.autodesk.com/t5/design-validate-document/offset/td-p/6004105
Here is also another demo:
http://forums.autodesk.com/t5/design-validate-document/fusion-360-offset-bug/m-p/5994236/highlight/t...
thanks
Well, I hope they manage to get it back to the way it was. In the meantime
I have to delete each link.
TrippyLighting
I hope they don't 😉
The parametric featrue of the new offset tool is of great help and has been requested many times. If you want to not take advantage of it, you can simply delete the offset symbol, which will still keep the offset entities. Then you can offset from the offset.
