What doesn’t the FIX constraint do for a spine?
laroot
Message 1 of 9
laroot
If I dimension a spline’s first and last points and then apply the FIX constraint to the spline, then what does the sketch lack that a fully constrained sketch would provide?
I can fully constrain even a fairly complex sketch made up of standard geometric elements.  But fully constraining a fixed point spline by hand quickly becomes burdensome when there are more than 3 points.  Is there a constraint or function to constrain a spline?
If not, is FIX a work around to prevent me from accidentally altering the spline in subsequent edits?
If I cannot/will-not fully constrain a spline, is it worthwhile to fully dimension the remaining elements
Very respectfully,
Larry
Replies (8)
Message 2 of 9
TheCADWhisperer
If you don't need to adjust the nodes or handles - you can use Fix.
Just select the spline. (Not the individual nodes.)
You can always toggle the Fix later if needed.
Message 3 of 9
g-andresen
When specifying splines, note that Control Point splines get by with 2 dimensions (vert/hor) per control point.
Fit Point splines, on the other hand, have 4 dimensions per point, 2 of which are necessary to define the tangent handles.
günther
Message 4 of 9
shahriarsifat1802164
Hi, basically spline gives an approximation of your desired sketch.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 5 of 9
I am going to make a screencast regarding this. Hope it will help.
Thank you.
RUET
Thank you.
Message 6 of 9
Here is it.
RUET
Thank you.
Message 7 of 9
Make a spline fully constrained | Fusion 360 | Autodesk Knowledge Network
RUET
Thank you.
Message 8 of 9
laroot
Guys,
Thank you for your comments and the screencast.
I apologize for not being clear:  I can and have fully constrained a spline.   It' just that doing so becomes a bother as the number of a spline's fixed points increases.
My current project is modeling a carved panel from an 18th century chest -- the Design model is a graphic made up of 37 arcs and 7 fixed point splines.  That section is then copied, rotated, and pasted to create a half model in which the laid out cavities get milled.  That half model is then mirrored to create the full panel.
In Sketchup, I can put dimensions in multiple layers to keep them manageable.  I haven't found a way to do that in Fusion 360.  As a result, even without trying to fully constrain the splines, there are a lot of closely spaced dimensions called out.  (I can uncheck dimensions to visibly remove them from the sketch, but it still strikes me as a mess.)
So I am trying to compare the benefits of (1) constraining nothing or only a few points, (2) fully constraining the arcs but simply FIXing the splines, and (3) fully constraining everything.
     What benefits do I get as I fully constrain more of the model?
     Is it worth doing for a 2D project?
Very respectfully,
Larry
Message 9 of 9
TheCADWhisperer
