What does a red "lock" icon mean on a sketch icon?
RogerInHawaii
Message 1 of 45
RogerInHawaii
I've get several sketches for a component and one of them has what looks like a small red "lock" icon on it in the lower right corner where the pencil icon normally is. What does it mean?
When I bring up the sketch to edit it, I can't see that there's anything wrong with the sketch. And I'm pretty sure I didn't do anything to "lock" the skecth, whatever that might mean. I
Replies (44)
Message 21 of 45
j4ck32
Community Visitor
Community Visitor
@Phil.E wrote:
Here's the help page that explains fully constraining a sketch:
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F2742DBC-8922-4071-A4BE-36AC90F56D52
the link is dead
Message 22 of 45
Phil.E
Thanks. Here's the new link:
http://help.autodesk.com/view/fusion360/ENU/?guid=SKT-FULLY-DEFINE-CONSTRAIN-SKETCH
The images and video are a little bit old, so the UI looks a little different. The workflow is the same. I've asked for an update to the imagery and video to keep the page updated.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 23 of 45
JRTG
As I had the same question as the OP, I can confirm the lock icon is not intuitive. 🙂
I agree with GRSnyder's suggestion to just remove the pencil overlay.
However, given that not-fully-constrained lines in a sketch are blue, and fully-constrained lines are black, I would reuse these same colors in the icons:
And consider to drop the overlay icons all together, as the black/blue color is a clear enough indication of the state:
Johan
Message 24 of 45
g-andresen
If it is important to you, you can create your own symbols in 16x16 px and exchange them for the standard graphic in the corresponding fusion file.
I use these symbols.
Günther
Message 25 of 45
chriswright_128
Add me to the list of people that assumed this meant the sketch was locked and couldn't be edited (especially when combined with Fusion's seemingly 50% chance of just ignoring me when I double click on a sketch to edit it). Its an extremely unintuitive way of conveying that something normal and good (a sketch being fully constrained) is happening.
Change it to literally anything other than a padlock icon and it would be an improvement... or at least show a tooltip explaining what it means when I hover over it.
Message 26 of 45
Phil.E
Thanks for the fresh suggestion for this issue.
Just in case you haven't seen it yet, there is an edit sketch command that can be accessed from the right click menu.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 27 of 45
GRSnyder
It's been a minute... I realized that I had no mental image of what the current visual states are, so I had to go check. Here they are as of July 2022:
Evidently, the ultimate outcome of this review was to keep the red padlock for fully constrained sketches and add a quarter-circle for unconstrained sketches. Because, you know, unconstrained sketches always have arcs in them and you have to remove the arcs to get the sketches fully constrained. Right? Right.
I hate to be a Negative Nancy, but this iconography seems even less clear than the version that was in use in 2019.
Consider, for example, that sketches are fully constrained on creation, because they're empty. So the first icon the user sees for a new sketch is an empty box with a padlock. Then they start adding geometry to the sketch, and the icon changes to a form that seems to convey the message "sketch with stuff in it." That makes perfect sense, except that it's not the intended meaning and so it's actively steering users away from an understanding of what's being indicated.
If you scrutinize the "unconstrained" icon, it turns out to be a bizarre combination of unconstrained (blue) points connected by apparently-fully-constrained black line segments. This situation is impossible to actually create in a sketch even if you explicitly try. In fact, it's the opposite of reality. Here's what an unconstrained rectangle with points at the corners looks like:
Blue lines, black points. (Because the points are constrained to the intersections; they are in fact fully constrained.)
But it doesn't really matter anyway, because the icon is so small and there's so little blue in it that it doesn't even read as "blue for unconstrained." It just looks generally grayer, with more "stuff" in it. (I have a high-density monitor, so the image displayed above is actually four times larger than what's displayed within Fusion 360.)
[Edit: Actually, now that I look at these icons in the context of Fusion 360 icons generally, I realize that all icons showing sketch geometry are composed of blue points and black lines. I can see why! It's just a lot more legible. But within the visual system as a whole it also means that blue dots with black lines means "normal, proper sketch geometry." It's the "fully constrained" icon that's the odd man out. Hmm.]
The outer box in all these icons is not a "page" or a "document" but a sketch square, although it's hard to see this without examining the icons in detail. The current "unconstrained" icon makes the corner points blue, which is to say, invisible at normal scale, so somehow you seem to have magically gone from a border that reads "sketch geometry" to a border that reads "document" which now has sketch geometry inside it. Wait, what?
Message 28 of 45
johan.rutgeerts
Sorry, you triggered me. I just have to rant now. Otherwise the itch doesn't go...  😉
The points on the corners should not be black. They are not fully constrained. Each of these points currently still has 2 degrees of freedom left.
Similarly, this is correct:
However this isn't:
That line should still be blue. It is not an infinite line, it is a line segment. And hence it is not yet fully constrained.
Or consider these two:
Identical line segments, each having one degree of freedom left.
Yes, I am sure that this makes perfect sense for the CS engineers who implemented it (or their manager!). But from an enduser / UX perspective, this does not make sense at all.
You can go on forever though:
Why does this one show a black dot:
Whereas this one does not:
That point still is equally constrained...
Anyway it is futile to think that colours, icons, etc will be addressed, as there are lots of bugs with higher impact that don't get resolved either...
Johan
Message 29 of 45
HughesTooling
@Phil.E  Could we have the lock icon in the timeline? It would be a lot more visible and useful if it showed in the timeline when a sketch is fully constrained.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Message 30 of 45
Phil.E
@HughesTooling
I cannot comment on anything else here. The discussion is lively and productive, and I am in no position to get involved here. But what you mention rises to the level of "near bug" in my eye.
If this was a new feature, the complaint would be easily summed up in this image.
For this inconsistent and confusing use of icons only (FUS-109750)
Thanks for pointing it out again.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 31 of 45
RogerInHawaii
Excellent idea! When I first posted this issue, years ago, that aspect of it never occurred to me. But you're right. If the sketch is not fully constrained and it shows that in the browser, it ought to show it in the timeline as well.
Do note, though, that this has been an issue, first brought up years ago, that has never been addressed, even though it ought to be an incredibly easy issue to fix, assuming they can agree on what images best represent the various states of a sketch.
Message 32 of 45
Leo_Dyn
I too would love to see the sketch showing constrained/unconstrained in the timeline.
In addition, I've been wanting to see it in a much more apparent spot while actually in the sketch as well. Especially if you don't have, or want to have the sketch section of the browser tree expanded. I was thinking something like the following maybe:
In the red and blue area, have one be a spot to click to activate the "show unconstrained sketch entities" without needing to open the command line. And in the other have it display the constrained/unconstrained status of that sketch. Seeing as the sketch palette is always showing while editing a sketch it would be a great spot for both....
Message 33 of 45
wcndave
Just so I understand, fully constrained also means constrained to the origin point?  How many people do that? I never do at least, am I missing something I should have been doing.
Also, son had a red locked sketch, and we cannot extrude anything from the sketch.  I assumed it was because the sketch was locked... and ended up here.  However, why can't we extrude a "fully constrained" sketch?
Message 34 of 45
Leo_Dyn
@wcndaveYes. It doesn't necessarily need to be ON the origin point, but it needs to be constrained to it in some way. so theoretically you could just dimension from some point on your sketch back to the origin point. The reason this would be necessary is otherwise you could drag the entire sketch around in space.... i.e. not constrained.
Message 35 of 45
HughesTooling
Doesn't have to be the origin, could be reference geometry projected into the sketch. But all sketches should be fully constrained.
If you can't extrude from a sketch, is it closed? Have you got the the show profile option checked?
Mark Hughes
Message 36 of 45
TheCADWhisperer
@wcndave wrote:
1.  How many people do that?
2. Also, son had a red locked sketch, and we cannot extrude anything from the sketch.
1. Every expert user fully defines their sketches.
@wcndave
2. Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply?
I wager that the experts here can find at least a half dozen other things you are missing.
Message 37 of 45
jamesloper
This really should be higher up in priority. The user interface is confidently telling you the opposite of what it meant, with far reaching repercussions for end users.
- Just remove the red padlock icon and you have solved the issue
- Want to make it even better? Replace the pencil icon with a small ! Exclamation point in a circle.
- For repetitions sake, show the status of the sketch within the sketch palette window. (Unconstrained vs Fully Constrained)
Message 38 of 45
jamesloper
Additionally, this is the kind of issue that gets pushed to the backlog forever. This is really a sign that you need to give the devs time to breathe. stop pushing for new features, it's not what is going to save you from Shapr3D as it starts to overtake the industry.
I have googled this problem twice in the last week. The first time I found this thread, I was like, Ohhhh, that's dumb. and promptly forgot about it because dumb things don't get remembered! Today I re-googled it and found this thread again and smacked my head when i realized it was the same dumb thing i just googled a week ago!
Its the same thing with traffic. you spend an hour in traffic and once its over you gladly forget about it, then another commute comes the next day, all the while eating away at your joy, never stopping to think "what can I do to fix this?" The lesson is, stop, take some time to assess and the best course of action might be to fix the problems you have right now instead of working the imaginary problems from the future.
Message 39 of 45
HughesTooling
A better option would be to make the sketch show yellow in the timeline and give a warning the sketch is not fully constrained. This way it would be more visible when a sketch is not constrained or an edit to reference geometry or  parameters results in a sketch no longer being fully constrained. Having it in a folder in the browser like it is now means you don't find the problem until you expand the folder or you actually have a problem where something is not accurate.
Mark Hughes
Message 40 of 45
TrippyLighting
I completely disagree!
Just because a sketch is not fully defined, does not mean there are issues with the design.
A yellow Icon men that a feature cannot be computed and the design remains functionals, but works with cached geometry.
A sketch that isn't fully constrained remains fully functional if the designer knows what they are doing!
Also, there are still way too many instances when the sketch engine still misses when a sketch is fully constrained, complains that its over constrained when it isn't and does not mark it as constrained when it is.
