I've designed a precisely beveled pentagon and hexagon to assemble into a truncated icosahedron (soccer ball).
I can't get the assembly to work, to make the faces go together in the right places.
In this attempt, I broke the links to the original files after importing them as components, and each has a plane through each mating face as well as a perpendicular plane bisecting the face.
I copied the hexagon component and pasted it 5 times, and also made a working copy of the pentagon, which I then grounded.
I don't understand why all the hexagons have their working panes tied together--if I turn of the visibility of one plane for one instance of the hexagon, it turns off for all of them. That's not fatal, but it's probably a clue.
These hexagons can be moved independently, but they are not really independent.
I know there's no way to do this easily in Fusion, because there's no 3D snap or constraint functionality, so I have to fake it with joints and align.
Align isn't enough, because I can't align two ways at once--I can align the face planes, but if I try to align the perpendicular planes I lose the face plane alignment.
So I need a joint. I've tried putting a cylindrical joint along matching face edges, and that works until I hit OK, whereupon there's an error about removing Body1, which makes no sense to me and anyway each component has a Body1 so who knows which one the error is about.
I've tried several strategies and spent a lot of time on this, searched for methods, but no joy.
Can anyone point me in a right direction?
One puzzle is that the hexagons are not really independent. I've tried isolating them, and did break the links to the original file. How do I get several instances of a component into one assembly so that they behave sensibly?
I added the hexagon and pentagon original design files, even though I unlinked from them in the assembly, in case the problem starts inside them.
Note that the hexagon's faces are not beveled at the same angle: alternate faces bond to other hexagons, and the rest bond to pentagons. The pentagon bonds only to hexagons, so all its faces are at the same angle.
