Welded Pipe & Fitting
I am a Fusion 360 novice and I cannot figure out how to do a simple welded pipe connection.  I'm hoping someone can bail me out.  I have a 3/4" threaded pipe tee and I want to weld a 3/4" Unthreaded pipe into one leg of the Tee (I don't want to use threaded pjpe).  A fillet won't work and I can't figure out how to draw a profile and sweep that will fill in the gap.  Any help would be greatly appreciated.
etfrench
You didn't specify if you wanted a butt or a sleeve joint.  This screencast shows a sleeve joint.  A butt joint would be done similarly.
Note: I made the weld a separate component in order to display it in a different color.  It also makes it easy to reuse it on other joints.
ETFrench
TheCADWhisperer
File>Export and then Attach your *.f3d file here if you still can't figure it out.
chrisplyler
Weird. In the field, we would use a weld-tee and weld threaded adapters onto the other two ends of it.
