Weird Stuff Happening After Update
oldtbone55
oldtbone55
After opening Fusion this morning and letting it update I closed the program and reopened it again only to find that when I tried to open one of my files to work on, half of the CAM setups were missing the toolpaths. I may not be explaining it correctly so I've attached the file and a screen shot.
kate.raskauskas
Hi @oldtbone55,
I'm sorry to hear that! Can you clarify for me whether you mean that there are operations missing (I see 3 operations under Setup 2 for example, should there be more?) or the operations themselves have different toolpaths than before?
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
oldtbone55
Hello Kate,
Under Setup1 (first operation) there was no longer an image showing of the
model and toolpath. All that was visible were the XYZ coordinates.
Thanks.
kate.raskauskas
Hi @oldtbone55,
Ok, thanks for the info! I was able to see the model when I opened your file; can you double-check to make sure the visibility is turned on for you?
As for the toolpath, it looks like the bottom height got set as the model top, which is why it couldn't generate toolpaths. I switched it to the model bottom and the toolpaths generated fine.
If you try that and you're not seeing it working, can you please send me a screenshot of what you are seeing?
Kate Raskauskas
