Message 1 of 10
Weird Edit Joint Behavior
So, I made a joint between two flat surfaces and then I had to edit it. Then this happened.
Fusion picked a new orientation for the joint. I figured, "No problem; I'll just move it back." Nope. It seems that the angle reference is lost or something. Multiple attempts gave the same result.
I ended up deleting the joint and making a new one. I have had other joint problems recently (a lot of broken rigid joints that were fine until re-opening a file), but I have been just deleting the joints and re-applying them.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
