Wall thickness
Wall thickness
Message 1 of 10
Wall thickness
Hey Guys, i have a problem (besides that i am a Fusion newbie).
I can't make my outer wall thicker (for 3D printing) is there a trick to do this?
If i try it with Push/Pull then it generates a error if i go over 0.1 mm 😞
Replies (9)
Message 2 of 10
Apologies if you already did this, but have you tried the modify => shell command?
Message 3 of 10
SaeedHamza
There are too many sharp angles in you model, and the thicken command will fail for more than a certain value, and looking at your design, it's a really small value
Could you share your design so that we can take a look
Regards
Saeed Hamza
Message 4 of 10
Hi
That's what i thought. Its a Logo for a Friend, so i can't really change it 😕
Anyway, i uploaded the design.
Message 5 of 10
laughingcreek
This is a bit of a heavy handed solution, but it will get you printing-
This is also assuming that this is the back part and won't be seen, just needs to be printable.
-on the original sketch trace another closed profile by hand, offset from the original.  It isn't necessary to follow the original exactly.  In fact I would greatly simplify it, taking out kinks and creating areas with more material at places where it gets thin.
-instead of extruding as a surface, extrude the new profile you just created.
Message 6 of 10
laughingcreek
So, I actually, you know, LOOKED at your design.  I think your best (but slow) option is to do basically what I said above, but accurately.  With all those crazy angles and narrow places your not going to get any of the offset or thicken type commands to work.
Message 7 of 10
cekuhnen
@Anonymous
welcome to Fusion
I am 100% sure thickness fails because your design has flames where the wall distance is smaller than + 0.1mm
Dont extrude the sides up but extrude the profile as a solid and then try the shell command in model work space
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 8 of 10
Tanks for the help, i'l will try it 🙂
Message 9 of 10
novakZ4XBZ
Observer
Observer
I just got done doing the same thing and mine has lots of angles too.  Do it from your edit sketch.  You can see the thickness if you enlarge it.  The numbers should be in the upper right corner.  I have the same issue.  It looks good on paper, until I need to print it.
Message 10 of 10
novakZ4XBZ
Observer
Observer
